5 Integrate SAS (Optional)
Oracle Clinical 5.2.2 supports the following configurations with SAS statistics application:
- SAS and Oracle Clinical database server on the same UNIX or Windows computer.
- SAS on a separate UNIX or Windows computer from Oracle Clinical within an intranet.
If the Oracle Clinical database server is installed on Windows, SAS must also be installed on Windows, even if it is on a separate machine. - SAS installed locally and Oracle Clinical installed in a hosted environment
For SAS to function with Oracle Clinical Data Extract, you must install these SAS components:
- Base SAS
- SAS/ACCESS
The SAS/ACCESS interface to Oracle requires Oracle SQL*NET on the computer where SAS is installed.
For more information, see:
