Verify the Application Tier Installation
- Verify that these URLs work and you can log into the application:
- https://host/opa522/launch.htm
- https://host/rdcadfsrnd/faces/Login
- The OPA_XMLTEMP_HTTP registry URL is used to communicate from the database server to the application server in order to retrieve the Patient Data Report PDF template created as part of DCI form generation. Ensure that this port is open on any firewall that exists between the application server and database server.
To confirm if the port is open:
- Follow instructions in My Oracle Support Article ID 1942747.1, 24311: 100501: Non-ORACLE Exception Error When Performing DCI Form Generation.
Parent topic: Install the Oracle Clinical Front End
