Design Installation Reference Codelists
Design Installation codelists are a subset of the Installation Reference Codelists relating to study design. Using a database role with access to the appropriate menu item, you can grant a study designer access to either of the Design Installation Codelists windows (Query or normal), and enable the designer to maintain this subset of the reference codelists without providing access to change all of the installation reference codelists.
Each of the design installation codelists is documented in the main Installation Codelists section:
Parent topic: Reference Codelists
