Defining Help for CRFs
To enter and update data in a CRF, users open the CRF in a Data Entry window. By default, the Data Entry window does not display the Help icon in its toolbar.
RDC adds the Help icon to the toolbar only if you create the context-sensitive help that displays when the user clicks the icon.
To create custom help text for the Help icon, you use the Maintain Links form in the RDC Administration application. For more information, see Defining a Link for CRF Help
Parent topic: Customizing Online Help
