Redeploying RDC with Customizations
RDC application files are inside the olsardc.ear archive, so whenever you make changes to a file, you need to redeploy RDC for these changes to take effect.
Redeploy RDC if you have applied any of the following customizations:
- Setting Web Command Access
- Customizing the Electronic Signature (Approval) Warning Message
- Customizing Online Help
- Made changes to the bc4j.xcfg file for performance customizations, as described in the section “Updating the bc4j.xcfg Settings" in the Oracle Clinical Remote Data Capture Onsite and Oracle Thesaurus Management System Browser Infrastructure Tuning Tips for Releases 5.0.1 and 5.1, available on My Oracle Support (Article ID 1965232.1).
To redeploy RDC:
- Log in to the administrator server console for the OPA domain using a URL of the form http://machinename:port/console. For example, http://pharma.company.com:7101/console.
- Click on Deployments and select the olsardc checkbox.
- Click Update.
- Click Next.
- Click Finish to complete the deployment.
- Restart the OPA server.
Parent topic: Deploying Customizations
