Upgrade the Domain Schema
When upgrading the application technology stack from 12.2.1.3 to 12.2.1.4 version the upgrade of the domain schema is not needed.
When upgrading the application technology stack from 12.2.1.2 to 12.2.1.4 version perform the following steps separately for both the FRDomain and OPADomain in the existing 12.2.1.2 User Projects Home.
  1. Run the following command in the new 12.2.1.4 ORACLE_HOME.
    <12.2.1.4_Oracle_Home>\oracle_common\upgrade\bin\ua.bat
  2. Select the All Schemas Used by a Domain check box and provide the domain location.
  3. Upgrade the components in FRDomain/OPADomain.
    • Oracle Platform Security Services - OPSS
    • Oracle Audit Services - IAU
    • Common Infrastructure Services - STB
  4. Create the component whose schema is missing in FRDomain/OPADomain.
    • Oracle WebLogic Services
  5. Check all prerequisites.
  6. Enter the administrator database account credentials for checking RCU. The account need to have DBA privileges (can be system account).
  7. Select the Create missing schemas for specified domain check box and enter the schema password.
    It is recommended to use the same password used for other RCU schema components.
  8. In the Examine screen, make sure all the checks should be green and status is not failed.
  9. In the Upgrade Summary screen, make sure all the information is correct.
  10. Click Upgrade.
