Use the Silent Installer (Optional)
You can run any of the Oracle Universal Installers—including the Oracle Clinical Database Server, Database, Front End, or Reports Server Installers—in silent mode. This may be useful to promote uniform installations in multiple sites or computers.
Oracle Clinical ships with .rsp (response) files that include parameter prompts and sample parameter values for each component. They are located on the Oracle Clinical and Oracle Thesaurus Management System 5.1 media pack disk under Disk1\stage\ Response in the .zip file for the application server or for the appropriate database operating system.
The table below lists each Oracle Clinical component, the response file name for each, and the section of this guide with information on the Installer parameters for each.
Table 1-6 Response Files and Parameter Information
| Component Installed | Response File | Parameter Information |
Oracle Clinical Database Server for Linux |
oracle.pharma.oc.server.unix.Complete.rsp |
Oracle Clinical Database Server for Solaris |
Oracle Clinical Database Server for HP |
Oracle Clinical Database Server for Windows |
oracle.pharma.oc.server.windows.Complete.rsp |
Oracle Clinical Database—fresh installation |
oracle.pharma.oc.db.install.Complete.rsp |
Oracle Clinical Database—upgrade and configure |
oracle.pharma.db.upgrade.install_type_1.rsp |
Oracle Clinical Database—reruns all the re-createable object scripts (views, packages, functions etc) against the database |
oracle.pharma.db.upgrade.install_type_2.rsp |
Oracle Clinical Front End |
oracle.pharma.oc.frontend.Custom.rsp |
Oracle Clinical Reports Server |
oracle.pharma.oc.reportserver.Complete.rsp |
Alternatively, you can run the Installer once, entering values on screen, and record the process to create a response file.
In UNIX:
./runInstaller
Or, if the database server has multiple Oracle Homes, then enter:
./runInstaller -invPtrLoc ORACLE_HOME/oraInst.loc
In Windows (as an administrator):
setup.exe -record -destinationFile complete_path_to_response_file_name
For more information about using response files see the 12.1.0.2 Oracle Database Installation Guide for your operating system:
Parent topic: Prepare to Upgrade Oracle Clinical
