Create the Repository Creation Utility
For this task, you need the following database server details:
- Host name
 - Port
 - Service name
 - Password for the SYS account
For instructions, see Oracle® Fusion Middleware Installing Oracle Forms and
                                                  Reports for Release 12.2.1.19, at https://docs.oracle.com/en/middleware/developer-tools/forms/12.2.1.19/install-fnr/installing-and-configuring-oracle-forms1.html#GUID-26210D99-290E-446D-B972-A81EA5C90CF9.
                                                  Run
                                                  $FMW_HOME/oracle_common/bin/rcu.bat.
                                                  Unless otherwise noted, click
                                                  Next to continue to the
                                                  next screen.
You can accept most default values, with the exception noted below.
Select Components
- Select the option Oracle Platform Security Services.
 - Enter the prefix name for the domains in the following format:
servernameFR
Schema Password
- Provide a schema password and make note of the schema name and password because they are required to configure the FRDomain.
Parent topic: Install and Configure the Oracle Application Tier
