Customizing Branding Images in RDC
In RDC, the page header displays the Oracle logo as the product logo in the top-left corner by default and also allows for adding a co-brand logo in the top-right corner. You can customize the application to add your own product image and a co-brand logo.
To customize the product and co-brand images:
- Create one or both image files in any format (for example JPG, GIF), as
follows:
- Product branding image: width of 155 pixels and height of 20 pixels.
- Co-brand logo image: width of 100 pixels and height of 20 pixels.
- Copy the image files to the
OPA_HOME\html\images
folder. For example,C:\opapps54\html\images
. - Navigate to the
middleware_home\user_projects\domains\FRDomain\config\fmwconfig\components\OHS\instances\ohs1\moduleconf.
- Open the file opa54_httpd.conf in a text editor and, if not already set, add
an alias for opa54, pointing to the html folder:
alias /opa54/ "C:\opapps52/html/"
- Save your changes and close the opa54_httpd.conf file.
- Repeat steps 3 through 5 for opa54_httpd.conf located under
middleware_home\user_projects\domains\FRDomain\config\fmwconfig\components\OHS\ohs1\moduleconf
. - Open the RdcLogos.properties file in a text editor. This file is in the
OPA_CONFIG_FOLDER
. The folder path is determined by the registry entry opa54, found underHKEY_LOCAL_MACHINE > Software > Oracle.
- To replace the product brand image that appears in the top-left corner of the RDC
pages:
- Find the string
image.ProductBranding=images/FNDSSCORP.gif
, whereimages
is the folder where you placed the image. This folder may have a different name in your environment. - Replace the text FNDSSCORP.gif with the name of the product brand image you created for step 1.
- Find the string
- To place a co-brand in the top-right corner of the RDC pages:
- Find the string
image.CoBranding=images/co_brand.jpg
. - Replace co_brand.jpg with the name of the file containing the co-brand image you placed in the images folder at step 1.
- Find the string
image.CoBrandingRendered=false
and replace the value with true.
- Find the string
- Save your changes and close the RdcLogos.properties file.
- Restart the OpaServer1 from the WebLogic Admin Console for the changes to take effect.
Parent topic: Customizing RDC on the Application Server
