Redeploying RDC with Customizations
RDC application files are inside the olsardc.ear archive, so whenever you make changes to a file, you need to redeploy RDC for these changes to take effect.
Redeploy RDC if you have applied any of the following customizations:
- Setting Web Command Access
- Customizing the Electronic Signature (Approval) Warning Message
- Customizing Online Help
To redeploy RDC:
- Log in to the administrator server console for the OPA domain using a URL of the form http://machinename:port/console. For example, http://pharma.company.com:7101/console.
- Click on Deployments and select the olsardc checkbox.
- Click Update.
- Click Next.
- Click Finish to complete the deployment.
- Restart the OPA server.
Parent topic: Deploying Customizations
