Gather Required Information for Oracle Clinical Front End
Have the following information ready to enter in the Installer screens:
  • Home Details: Enter the following:
    • Name: OPA_HOME
    • Path: C:\opapps52
      Use the same location used for Oracle Clinical 5.2.1 or later installation.
    If Oracle Clinical 5.2.1 or later, or TMS 5.3.x has already been installed on this application server, OPA_HOME may already be set to C:\opapps52 or similar path and you must use this for Oracle Clinical 5.4.1 too. Do not create a new OPA_HOME if this was already created. The Oracle Clinical 5.2.x components will be placed by the installer under this OPA_HOME at the specified location for the Oracle Clinical 5.4.1 release.
  • Java Home is the location where JDK 1.8.0_391 or higher was installed
  • Oracle Fusion Middleware home directory:
    • If the technology stack has been upgraded from version 12.2.1.3 to 12.2.1.4, use the new 12.2.1.4 Oracle Home (post upgrade one). The upgrade to 12.2.1.4 is an out-of-place upgrade and a new oracle_home is created; for example, C:\Oracle12214\Middleware\Oracle_Home.
    • If the technology stack was fresh installed at version 12.2.1.4, for example if OC 5.2.2 Front End was already installed use the Oracle Home you had at the time of technology stack installation; for example, C:\Oracle\Middleware\Oracle_Home.
  • Oracle Fusion Middleware User Projects directory:
    • If the technology stack has been upgraded from version 12.2.1.3 to 12.2.1.4, use the initial 12.2.1.3 Oracle Home (pre upgrade one) to select the user projects directory. The upgrade to 12.2.1.4 is an out-of-place upgrade and the domains reside in the 12.2.1.3 oracle home; for example, C:\Oracle\Middleware\Oracle_Home\user_projects.
    • If the technology stack was fresh installed at version 12.2.1.4, for example if OC 5.2.2 Front End was already installed, use the Oracle Home you had at the time of technology stack installation; for example, C:\Oracle\Middleware\Oracle_Home\user_projects.
  • OPA home directory: By default, it is C:\opapps52.
    Use the same location used for OC 5.2.1 or later installation.
  • OPADomain Administration Server configuration details:
    • Listen address
    • OPADomain Listen port number
    • OPADomain SSL listen port number
    • OPADomain WebLogic username
    • OPADomain WebLogic password
  • OPADomain Node Manager configuration details:
    • Listen address
    • OPA Domain NodeManager Listen port number
    • WebLogic username
    • WebLogic Server password
  • Database details (database used for data source created under OPADomain):
    • Server.Domain: for example, servername.your_company.com
    • Port number
    • Database service name
    • RDC Proxy Password (rdc_midtier_proxy)—the password you created when installing Oracle Clinical database objects.
  • Managed Server configuration details:
    • Number of Managed Servers
    • Listen port start index
  • Online help URL: If you have customized the online help, the URL where the customized online help is located.
