PreviousNext
JavaScript must be enabled to correctly display this content
Install the Oracle Forms and Reports Servers
In the staging area where you downloaded the media pack (see Download the Software), locate the directory where you downloaded Oracle Forms and
Reports 12c (12.2.1.19) for Microsoft Windows (64-bit) and extract the .zip file
(V1033711-01) if you have not already done so.
Install the Oracle Forms and Reports 12c (12.2.1.19) using a Generic Package
installer—This type of installer is an .exe file;
setup_fmw_12.2.1.19.0_fr_win64.exe.
When asked, to choose an installation type, select Forms and
Reports Deployment.
