7 Set Up SAS
Oracle Clinical supports the following configurations with SAS:
- SAS and Oracle Clinical on the same UNIX or Windows computer
- SAS on a separate UNIX computer from Oracle Clinical within an intranet
If the Oracle Clinical database server is installed on a Windows computer, SAS must also be installed on a Windows computer.
The SAS/ACCESS Interface to Oracle requires Oracle SQL*NET on the computer with the SAS software installation. For this statistics application to function with Oracle Clinical Data Extract, you must install these SAS components:
- Base SAS
- SAS/ACCESS
For more information, see:
