For Pre-3.1-Style Study Views
The View Creation Mode field in the PSUB window allows you to specify whether and how the validation status of the data should be included in the views.
When you specify in this field that response status information should be included in view creation, this applies to all views except externally loaded views.
You can create views in three modes:
with (response) data only
with both response and validation status data in the same view
with validation status and response data in separate views
Parent topic: Validation Status and Views
