Browse the Audit Trail
The Browse Audit Trail window displays the history of changes to RDCIs, RDCMs and Questions. All fields are display-only, but you may want to invoke the Editor window to browse responses that are too long to display completely in the Browse Audit Trail window. Click in the response field that you want to browse, then invoke the Editor window by selecting Data, then select Edit Field. Alternatively, press Ctrl + E.
Access
Access the Browse Audit Trail window in either of the following ways:
  1. From the tree, select Conduct then, select Data Validation then, select Discrepancy Database menu path. The system opens the Profiles for Discrepancy Management window. Select Special then, select Audit RDCIs menu command.
  2. In the Browse window, with a document open, select Action then, select Audit menu command.
