Changing Discrepancy Display Layout and Filtering the Data Displayed
You can both customize the display of the multi-record view of the Maintain Discrepancy Database window and filter the discrepancies displayed there.
Your organization may have one or more pre-defined layouts available. In multi-record view, from the Special menu, select User Group Layouts, then select Default Layouts. Then choose a layout name from the list of values. When you click OK, the system reorganizes the discrepancy details according to the selected layout.
Information on customizing layout definitions is included in the Oracle Clinical Administrator's Guide chapter on configuring discrepancy management.
See also the following topics:
