Defining a Mass Change Specification and Its Criteria
The Mass Change utility has two panels. The top panel, which shows the change type and study name in its title bar, is where you define the MCS you want to perform by giving it a name, description, and other details (see Defining the Mass Change Specification). The CDS Criteria panel, below, is where you build a SQL statement to specify the records to which you want to apply the mass change (see Defining Candidate Data Set Criteria).
