Defining a Rollback Segment
To prevent exceeding the rollback segment space and causing the entire job to fail, you can choose to run the batch data loader in its own rollback segment. Define the rollback segment as follows:
- Define and tune a rollback segment and bring it online, following instructions in the Oracle SQL Reference manual.
- Enable the segment for use in Oracle Clinical by adding the entry BDL_R_ SE to the reference codelist OCL_STATE. For further information on this reference codelist, see the Oracle Clinical Administrator's Guide.
Parent topic: Setting Up for Batch Data Loading
