PreviousNext
JavaScript must be enabled to correctly display this content
To Delete Logged-in RDCIs
Select Data Entry then, select Key Changes.
Enter the Document Number and press Return.
From the Forms message box that displays, select Update Existing.
The RDCI displays.
Select Delete Record.
The system sets the Status field to REMOVED in the RDCI and all its associated RDCMs. This makes these records inactive, but leaves them in the database. Select Exit from the Action menu when your changes are complete.
