Deleting an Externally Loaded View
To delete an externally loaded view, from the Conduct menu, select Data Extract, then select Delete External View. A PSUB window called Mark an Externally Loaded View for Deletion appears. Enter the name of the view you want to delete. Click the Submit Job button. The view is marked for deletion. The next time data extract view maintenance is run, this view is deleted.
Parent topic: Data Extract View Loader
