Enabling and Disabling Pass 2 Required
You can choose to require Second Pass Data Entry on a study-by-study basis. The Enable/Disable Pass 2 Required batch job changes the Pass 2 Required status for the currently selected study.
The consequences of changing this requirement in an ongoing study with existing data are:
- If you require Pass 2 for a study with previously collected data, the collected data becomes inaccessible until Pass 2 Data Entry is completed.
- If you disable Pass 2 Required for a study with collected data with Pass 2 complete, there is no change to data with Pass 2 complete. If there is any data with only Pass 1 complete, it becomes accessible.
To enable or disable Pass 2 Required for a study:
Parent topic: Security Settings for Study Conduct
