Executing a Single Procedure
If you want to check Study data for discrepancies generated by a particular
Procedure, you can execute that Procedure at any time, independent of batch validation.
Go to Conduct, then Data Validation, and then Execute a Single Procedure.
- If you are not already working on a particular Study, choose a Study from the pop-up List of Values.
- In the Current Value column of the Procedure Name row, choose the Procedure you want to execute from the drop-down list.
- Enter a Procedure Version Sequence Number
- In the Execute Procedure in Debug Mode line, choose Y to run in Debug mode and N to run in regular mode.
- Submit the job.
Parent topic: Using the Discrepancy Database
