Patient Enrollment
DCI book sequencing is based on patient associations. When you are working in Data Entry modes that query existing received DCIs, such as first- or second-pass entry, Browse, or Update, you must query against an existing patient position to utilize DCI book sequencing. If you perform a query and do not fill in the Patient field, DCI book sequencing does not occur, even if DCI book sequencing is enabled.
If you have the proper privileges, you can associate patients to a DCI book in the Design subsystem's Maintain Patient Positions window or the Data Entry subsystem's Maintain Patient Enrollment window.
In each of these windows, the field DCI Book Name establishes the name of the DCI book to associate with this patient position. A List of Values is available. If no DCI Book name is associated with a particular patient position, then Oracle Clinical uses either the DCI book currently used in data entry or the default DCI book assigned to the study when no DCI book is used.
The field is protected if production data has been entered for that patient.
