Single Default Values
During DCM question definition, a default response value can be defined for a given question in either a repeating or a non-repeating question group. When the field is displayed during both first-pass and second-pass entry, the default value displays in the field and need not be re-entered. If the field is enterable, you can modify the default value. In repeating question groups, single default values are displayed in each row when you first go to a new repeat, but are treated as entered data only if you explicitly enter data for other fields on the repeat.
Parent topic: Default Values
