Single-Record View
Single-record view is the default arrangement of the Maintain Discrepancy Database window.
Figure 4-1 Single-Record View of the Maintain Discrepancy Database Window
Description of Figure 4-1 follows
Description of "Figure 4-1 Single-Record View of the Maintain Discrepancy Database Window"
In single-record view the window displays all of the information related to a single discrepancy. It has four sections:
  • The Discrepancy section, at the top of the window and labeled Discrepancy, displays information about the discrepancy's patient, visit and DCM information; system, review, and resolution statuses; and comments associated with each status.
  • The Characteristics section provides information on the cause of the discrepancy. The information displayed varies depending on the type of discrepancy. The value of the discrepant response is displayed for all types except multivariate discrepancies; since more than one response is involved in creating a multivariate discrepancy, you must click on the More button to see all the contributing responses.
  • The Related Information section contains further information about the question and the discrepancy, including two flexfields your company can utilize.
  • The Current DCF section identifies the DCF associated with the discrepancy, if any. If the discrepancy is not linked to a DCF, the fields in this section are blank. (See Using Data Clarification Forms.)
For more specific information, see Maintain Discrepancy Database Window Fields.
You use the Exit button to cancel a query, discard changes, and to close the window. You can use the Save button on the window or toolbar, the F10 key, or from the Data menu, select  Save to save changes without exiting the window.
In Enter Query mode, the field background color changes to blue. Click F7 to enter query mode, the Exit button to cancel a query, and F8 to execute a query. For more information on query functions, see Introducing the Oracle Clinical Interface in the Oracle Clinical Getting Started manual.
