Standard Batch Data Load and Out of Study Batch Data Load
Oracle Clinical offers two batch data load processes. Both processes can handle multiple data files at a time.
This option can handle only a single DCM in a single DCI in each data file; this usually corresponds to a single, relatively simple CRF (see Oracle Clinical Creating a Study for information on DCMs and DCIs). All data must be for a single study.
To use this process, select Batch Data Load from the Conduct menu.
This option can handle multiple DCMs in a DCI, and multiple DCIs in a data file and can process data from multiple studies at the same time. You may choose to use the Out of Study option even for a single study because it allows multiple DCMs and DCIs per data file.
To use this process, select Out of Study Load from the Conduct menu.
Parent topic: Batch Loading Data
