Assigning Compounds
To assign compounds to the selected program, click the Compounds Assigned to Program button. The Compounds for Program window opens, displaying the details of the compounds for the selected program.
To enter a new compound, click the Insert button. You can assign a compound to a particular program only once. Use the list function to choose from existing compounds. Choose the Primary field if this is the primary compound under investigation in this program. You can only designate one compound assigned to this program as the primary compound. This field defaults to selected when the first compound is assigned to the program. You can change this designation at any time.
The system populates the Compound Code and Description fields, according to the compound values set in the Maintain Active Substances window. There are two columns under the field title Compound Code. The first is the Compound Code, the second is the Compound Subcode. The subcode column has values only if your company uses subcodes to classify compounds.
As you add compounds, assign one of them as the primary compound. This affects Oracle Clinical reports and window displays, but you can change this designation at any time.
Parent topic: Planning and Designing a Study
