8 Global Library Activities
The Global Library is an organization-wide central repository for containing standardized data definitions. You can partition the Global Library into domains so to accommodate different definitions of the same data objects. This chapter describes the Oracle Clinical's utilities for managing Global Library definitions.
In this section:
