Study Site Plans
Use this window to plan the enrollment details for a site. To maintain the records for a planned study site:
- From the Design menu, select Studies, then choose Study and Site Plans, and click the Sites button. The Study Site Plans window appears.
- Create site plans by clicking the Create Initial Plans button. Defaults from the values supplied in the study plan give the initial values for the site plans.
- When new sites are added to the study after the planning process has started, create initial plans for the new study sites by clicking the Create Initial Plans button. As a result, Oracle Clinical creates plans only for study sites that do not yet have plans, and leaves existing plans untouched.
The actions you can perform in the study sites window are identical to the actions you can perform at the clinical study level.
Parent topic: Planning and Designing a Study
