Using Oracle Clinical-Siebel Clinical Integration
If you are using both Oracle Clinical and Siebel Clinical for a clinical study, you can integrate the two systems to automatically pass certain data and metadata from one system to the other in order to:
Signal the completion of visits and activities.
Simplify study setup in Oracle Clinical and Subject setup in Siebel Clinical.
You can also integrate Oracle Clinical with other clinical trial management systems. For further information, see Integrating with a Clinical Trial Management System
Parent topic: Planning and Designing a Study
