Gather Required Information for the Oracle Clinical Front End
Have the following information ready to enter in the Installer screens:
- Home Details: Enter the following:
- Name: OPA_HOME
- Path: c:\opapps54
- Java home is located in version JDK 1.8.0_251 or higher.
- Your Oracle Fusion Middleware home directory; for example:
C:\Oracle\Middleware\Oracle_Home
- Your Oracle Fusion Middleware user project directory; for example:
C:\Oracle\Middleware\Oracle_Home\user_projects
- Your OPA home directory; by default:
C:\opapps54
- Cluster Configuration:
From Oracle Clinical release 5.2.0 onward, Oracle Clinical installer supports cluster configuration. For configuring cluster environment:- Identify the primary and secondary nodes of application servers which will be part of the cluster.
- Install the technology stack in all nodes.
- Configure FRDomain only on the primary node.
- After installing the technology stack, use the Oracle Clinical installer to install primary and secondary nodes by selecting the cluster options.
- For configuring the standalone server:
Select the No option (default value) in the Cluster Configuration screen.
- For configuring the primary node cluster:
Select the Yes option in the Cluster Configuration screen.
To install the primary node, select the Yes option in the Node Configuration screen, and enter the secondary node server details:
SecondaryNodeServer.Domain:Port Number; for example:
secondary_node_server_name.your_company.com:port_number
- For configuring the secondary node cluster:
To install the secondary node, select the No option in the Node Configuration screen, and enter the primary OPADomain Admin Server details in the Admin Server Configuration screen.
- WebLogic username: The account created when you installed the WebLogic Server.
- WebLogic Server Password: Enter a new password or use the password you created when installing WebLogic Server.
- Admin Server configuration details:
- Listen address
- Listen port number (default is 7101)
- SSL listen port number (default is 7102)
- WebLogic username
- WebLogic Server password
- Node Manager configuration details: We recommend you to use the default values.
- Listen address
- WebLogic username
- Database details:
- Server.Domain; for example:
servername.your_company.com
- Port number
- Database service name
- RDC Proxy Password (rdc_midtier_proxy)—the password you created when installing Oracle Clinical database objects
- Your OPA backup directory:
C:\opa_backup
- Oracle Fusion Middleware Repository Creation Utility (RCU) configuration details:
- Schema prefix
For setting the schema prefix, we recommend you to:- Set a value which is not in use
- Set a value that does not start with a number
- Specify it in the format HostNameOPA
- Use only alphanumeric characters
- Set a value that does not contain any special characters
- Set a value of length not more than 12 characters
- Database administrator username and password
- RCU schema password
- Schema prefix
- Wallet location: for the Wallet you created in Enable SSL Between a Browser and Oracle HTTP Server. (You can browse for it on screen.)
- Managed Server configuration details:
- Number of Managed Servers
- Listen port start index
- Online help URL: If you have customized the online help, the URL where the customized online help is located.
Parent topic: Install the Oracle Clinical Front End
