Install Oracle Java Development Kit
To install Oracle Java Development Kit (JDK):
  1. If you have not already done so, follow instructions in Download Oracle Java Development Kit.
  2. Follow instructions in the release notes to apply the patch.
    Do not use the default download location. By default, the download directory is C:\Program Files\java\jdk. "Program Files" includes a space, which can cause problems. Oracle recommends specifying a directory with no spaces in the name.
    In addition, the directory name must have no more than 8 characters; for example, C:\app\java\jdk.
  3. Make a note of the directory in which you install JDK. You will need it when you install WebLogic Server.
