Regenerating SAS Views Created in Pre-5.0 Oracle Clinical Releases
SAS views generated in earlier releases are not usable in Oracle Clinical Release 5.0 and later, because 5.0 and later require a different connection string to be embedded in the SAS files. You must re-run all jobs to create new *.sas files. Use the utility gen_views for this purpose; see Generating Data Extract Views.
For more information and other options, see Data Extract batch jobs fail in INCREMENTAL mode (after upgrading from OC 4.6.x to 5.x.x) (Doc ID 2029953.1) on My Oracle Support.
Parent topic: Configuring Data Extract
