Setting Values in the OCL_STATE Local Reference Codelist
The OCL_STATE local reference codelist includes several parameters that control discrepancy database and DCF functions, as well as many other parameters. The following table describes the discrepancy management parameters.
Table 3-14 Settings in the OCL_STATE Codelist for Discrepancy Database Functions
Short Value (Parameter Name) | Long Value (Settings) | Description |
The single-record mode of the Maintain Discrepancy Database form's Characteristics panel has a button that toggles the three long value settings. Choose the value to display by default. |
If set to Y, changes to comment and resolution text entries in DCFs automatically propagate to the discrepancy database |
The system does not use this setting. |
If set to Y, the system automatically populates the CRF Page Number field of the Maintain Discrepancy Database form. |
Parent topic: Configuring Discrepancy Management
