System Reference Codelists
System reference codelists provide values for Oracle Clinical's internal use only. You can browse or query for system codelist values, but you cannot change them. System codelists provide standard values across distributed environments.
To access the System codelists, navigate to Admin, Reference Codelists, and then Qry System Codelists. Alternatively, you can run a Reference Codelist report for one or all system codelists. See Running the Reference Codelists Report for instructions.
Parent topic: Reference Codelists
