CLOB Conversion Error Opening Data Entry Window
If you receive an error when opening a data entry window that includes text about CLOB conversion, you may need to change the Wrap Data Types setting in the connection pool for the data source of the database.
During RDC installation, the Oracle Universal Installer creates one connection pool. If you set up additional connection pools manually, you must uncheck the Wrap Data Types setting for each one.
