B Generating HTML DE and PDR Templates for Existing DCI Form Versions
To use HTML Data Entry and the graphic Patient Data Report (PDR), you must design graphic layouts for the CRFs. For information on creating layouts and enabling studies for data entry using DCI Forms, see Oracle Clinical Creating a Study.
If you have existing DCI Form Versions where the PDF form was generated, run the upgrade utility to generate BI Publisher Report Templates and HTML Data entry forms for the existing form versions.
You do not have to change your existing layouts. The Report templates and HTML DE forms look the same.
To enable image viewing on CRFs during data entry in RDC, you can choose either to set up a central repository or to copy images to all RDC installations. For information on enabling image viewing, see the Oracle Clinical Administrator's Guide.
This appendix includes the following topics:
