Map Network Drive for Image Browsing
If you intend to use this client to design graphic CRFs, you can enable an image browsing feature to simplify inserting graphic images in your layouts. Instead of entering the exact path and file name into the Insert Image field, you can use the standard Windows Browse button.
You must first set up the Forms Server where you store your images. See Share the RDC Directory for Image Access for details.
To enable image browsing, you must permanently map the Forms Server's drive to this client:
  1. Open My Computer.
  2. Open the Tools menu, and then select Map Network Drive.
  3. Enter the drive letter that you want to assign to this connection.
  4. Enter the path of the folder you want to be able to access. Alternatively, you can click Browse to select the folder location.
  5. Click Finish.
