Run the Reconfiguration Wizard
Run the Reconfiguration Wizard For FRDomain
- Open a DOS prompt and run:
<12.2.1.4_Oracle_Home>\oracle_common\common\bin\reconfig.cmd -log <path_to_log_file>\FRDomain_log.txt -log_priority=ALL
You can accept most default values, with the exception noted below.
Select Domain
- Select the FRDomain location; for example:
C:\Oracle\Middleware\Oracle_Home\user_projects\domains\FRDomain
Database Configuration Type
- Select the RCU data check box under Specify AutoConfiguration Options Using.
- Make sure the RCU database is correct.
- Click Get RCU Configuration.
Component Datasources
- Select all RCUs.
- Click Next.
Advanced Configuration
- Select only the Topology check box in the Advanced Configuration in the Reconfiguration Wizard.
Do not select the System Components check box. Those are automatically configured/upgraded by the Upgrade Assistant in the next steps.
Make a note of the FRDomain defaultCoherenceCluster port because for OPADomain a different port needs to be used. By default, it is 7574.
Run the Reconfiguration Wizard For OPADomain
<12.2.1.4_Oracle_Home>\oracle_common\common\bin\reconfig.cmd -log <path_to_log_file>\OPADomain_log.txt -log_priority=ALL
Select Domain
- Select the OPADomain location; for example:
C:\Oracle\Middleware\Oracle_Home\user_projects\domains\OPADomain
Datasources
- Select the existing data sources.
- Select all RCUs.
- Click Next.
- Select all check boxes.
Default Coherence Cluster
- Use a different port number other than the one used for FRDomain. For example, 7575.
Domain Frontend Host
- Deselect the Configure Domain Frontend Host check box.
Parent topic: Upgrade and Configure the Oracle Application Tier
