Test the Reports Server Installation
To test that the Reports Server can create printouts and files:
- Start Oracle Clinical.
Navigate to Admin, Admin Reports, and then Reference Codelist. The Report Reference Codelist submission screen opens.
- Click the Reference Codelist Name field, and enter OCL_STATE.
- Print the report:
- Click the Job Details button.
- Change the Output Type to PRINTER.
- Examine the printer's path to see if it is correct.
- Click Submit Job. You receive a status prompt. Close the prompt to return to the Submission screen.
- Click Job Status to check the progress of your print job. Look for the printout from your printer.
Print the report to file:
- Return to the Report Reference Codelist submission screen.
- Click Job Details.
- Change the Output Type to FILE.
- Click Submit Job. The system displays a status prompt. Close the prompt to return to the Submission screen.
- Click Job Status.
- Check its status in the Execution Status field.
- Click View Output. The system displays a path location prompt.
- Click OK. The Report Server processes the file and converts it to the selected format. If successful, the file then opens in a separate window.
Parent topic: Upgrade the Oracle Clinical Reports Server
