Upgrade to Release 4.6.2
Upgrade to Release 4.6.2, if you are using a release prior to 4.6.2.
If you are currently using a release of Oracle Clinical prior to Release 4.6.2, you must first upgrade Oracle Database, the Oracle Clinical database server and Oracle Clinical databases to Release 4.6.2.
You do NOT need to install the 4.6.2 application tier because the technology stack is new in Release 5.x and you must do a fresh install of the whole application tier.
If you are already using Release 4.6.2 or higher, you can skip this section.
Parent topic: Upgrade to Release 4.6.6 (If Needed)
