Edit setDomainEnv.sh
As directed in Edit setDomainEnv.sh add the parameter -DhandleDiscEvent set to True on one and only one application server.
This is required to support multiple middle tiers pointing to the same database. Only the server with this parameter set to True will be able to send data from TMS to InForm.
Parent topic: Install Oracle Thesaurus Management System (Optional)
