Create database accounts
Study configurators need a database account to create and modify studies and study components. People viewing DMW data through a visualization tool also need database accounts.
  1. Log in to Oracle LSH.
  2. Expand the Life Sciences Data Hub node in the main menu on the left or from the Navigator drop-down. Select Database Account.
    Or, if Oracle LSH is already open, go to the Administration tab and select the Database Account subtab.
  3. Click Create.
  4. Enter values in the following fields:
    • User Name. Click the Search icon and enter search criteria for the Oracle LSH user for whom you are creating a database account.
    • Database Account Name. Enter a username for the database account. The text you enter is stored in uppercase.
    • Password. Enter a password of 8 characters or more for the Definer to use with the database account.
    • Confirm Password. Reenter the password.
      For security reasons, the user should reset the password in his or her Preferences screen.
  5. Click Apply. The system returns you to the Database Account screen.
