Create user accounts
  1. Log in to Oracle LSH.
  2. Select User Management from the main menu on the left or from the Navigator drop-down.
  3. Click Users.
  4. In the Register drop-down, select External Organization Contact and click Go.
  5. Enter values in the following fields:
    • Email. The user's email address.
    • Name Fields
    • Organization. Enter or search for the Organization to which the user belongs.
      You must set up the list of allowed values as a post-installation step for Oracle Applications, as described in the Oracle® E-Business Suite System Administrator's Guide - Security.
      See http://download.oracle.com/docs/cd/B53825_08/current/acrobat/121sasg.pdf.
    • Phone Number
    • Account Information--Password. If you select Generate Automatically, the system generates and emails the password to the user's email account.
      If you select Enter Manually you must type and confirm the password an inform the user what it is. The user must reset the password in either case.
      You can set the minimum length and other requirements for passwords; see Set login-related and other profile values.
  6. Click Submit.
  7. Click OK.
