List of adapters
DMW uses the following adapters. Other adapters appear in the Oracle LSH UI, but they are used only in LSH.
  • The InForm Family Adapter includes:
    • InForm Data is required for users to set up an InForm clinical data model, including loading data from InForm and scheduling data loading.
    • InForm Metadata is required for users to set up an InForm clinical data model, including loading InForm metadata.
  • Oracle Export is required for users to create, modify, or install a clinical data model that is set up for exporting data in an Oracle Export file. It is also required to run the job to create the Oracle Export file.
  • The Oracle Family Adapter is not required.
    • Oracle Tables and Views is not supported in this release.
    • PLSQL This adapter is used internally. Users do not need access to it.
  • SAS Export is required for users to create, modify, or install a clinical data model that is set up for exporting data in a SAS file. It is also required to run the job to create the SAS file.
  • The SAS Family Adapter includes:
    • SAS is required for users who upload SAS files to create table metadata in clinical data models.
    • SAS Program is required to upload SAS programs or to run a transformation or validation check that uses a SAS custom program.
  • Text Export is required for users to create, modify, or install a clinical data model that is set up for exporting data in a text file. It is also required to run the job to create the text file.
  • The Text Family Adapter/Text is required for users who create an input file clinical data model of type Text.
  • The Visualization Adapter/Generic Visualization is required to view data using a visualization tool.
