Oracle LSH Object Operations
  • Application Area: Create Work Area
  • Application Area: View
  • Domain: Create Data Model
  • Domain: Create Load Set
  • Domain: Create Variable
  • Domain: View
  • Load Set: View
  • Load Set: Modify
  • Load Set: Modify Val Status to QC
  • Load Set: Modify Val Status to PROD
  • Table: View
  • Table: Modify
  • Table Instance: Modify
  • Table Instance: Remove
  • Table Instance: Modify Val Status to QC
  • Table Instance: Modify Val Status to PROD
  • Variable: Modify
  • Variable: Modify Val Status to QC
  • Variable: Modify Val Status to PROD
  • Work Area: Create Table Instance
  • Work Area: Create Load Set Instance
  • Work Area: Modify
  • Work Area: Modify Val Status to QC
  • Work Area: Modify Val Status to PROD
  • Work Area: Delete
  • Work Area: Deploy (Install)
  • Work Area: View
