Oracle LSH Object Operations
  • Application Area: Manage Security
  • Application Area: Create Work Area
  • Application Area: Create Program
  • Domain: Create SubDomain
  • Domain: Modify
  • Domain: Delete
  • Domain: Manage Security
  • Domain: Create Load Set
  • Domain: Create Variable
  • Domain: Create Program
  • Domain: Create Data Model
  • Domain: Create Transformation Map
  • Table Instance: Manage Security
  • Work Area: Manage Security
  • Work Area: Create Table Instance
  • Work Area: Create Load Set Instance
  • Work Area: Modify
  • Work Area: Modify Val Status to QC
  • Work Area: Modify Val Status to PROD
  • Work Area: Delete
  • Work Area: Deploy (Install)
  • Work Area: Create Program Instance
  • Variable: Modify
  • Variable: Modify Val Status to QC
  • Variable: Modify Val Status to PROD
