Oracle LSH Object Operations
  • Application Area: Manage Security
  • Domain: Manage Security
  • DataModel: Manage Security
  • Execution Setup: Modify Val Status to PROD
  • Execution Setup: Modify Val Status to QC
  • Execution Setup: Submit
  • Execution Setup: Manage Security
  • Program: Manage Security
  • Program: Modify Val Status to PROD
  • Program: Modify Val Status to QC
  • Program: Modify
  • Program: Remove
  • Program Instance: Modify Val Status to PROD
  • Program Instance: Modify Val Status to QC
  • Program Instance: Create Execution Setup
  • Program Instance: Remove
  • Table: Manage Security
  • Table Instance: Manage Security
  • Table Instance: Modify
  • Table Instance: Remove
  • Table Instance: Modify Val Status to QC
  • Table Instance: Modify Val Status to PROD
  • Table Instance: ReadData
  • Table Instance: BlindBreak
  • Table Instance: Unblind
  • Table Instance: ReadUnblind
  • VC Batch: Manage Security
  • Work Area: Manage Security
