Oracle LSH Object Operations
  • Execution Setup: Manage Security
  • Program: Manage Security
  • Program Instance: Manage Security
  • Program: Modify Val Status to PROD
  • Program: Modify Val Status to QC
  • Program: Modify
  • Program: Remove
  • Program Instance: Modify Val Status to PROD
  • Program Instance: Modify Val Status to QC
  • Program Instance: Create Execution Setup
  • Program Instance: Remove
  • Table: Manage Security
  • Table: View
  • Table: Modify
  • Table: Modify Val Status to PROD
  • Table: Modify Val Status to QC
  • Table: Remove
