Oracle LSH Object Operations
- Load Set Instance: Modify
- Load Set Instance: Modify Val Status to QC
- Load Set Instance: Modify Val Status to PROD
- Work Area: Create Table Instance
- Table Instance: Modify
- Table Instance: Remove
- Table Instance: Modify Val Status to QC
- Table Instance: Modify Val Status to PROD
- Work Area: Create Loadset Instance
- Work Area: Modify
- Work Area: Modify Val Status to QC
- Work Area: Modify Val Status to PROD
- Work Area: Deploy (Install)
Parent topic: Clinical Data Models and Query Builder
